Headsets are one of the few areas if bike maintenance that do my head in!
I have a frame with a tapered head tube. From what i can work out, the upper has a diameter of 44mm and lower 56mm. I assume these are inside diameter measurements (I haven’t got the frame yet – still in the mail).
I want to use my 1.5″ steerer fork. I believe this can be done by using an external cup for the upper headset. Because it is not a standard 1.5″ head tube.
Does anyone know where I can get such a headset. I know that nukeproof warhead do the upper , but don’t sell it separately (it comes with the lower which is of no use to me because it is for a 44mm lower diameter. See link http://www.chainreactioncycles.com/mobile/au/en/nukeproof-warhead-44eeos-headset/rp-prod85870
Hope do mix and match headsets, but I can’t find the right upper.
Any suggestions. I am on a tight budget, and I don’t want to buy 2 headsets. Or buy new tapered steerer forks.
Thanks.
