The bearings should just drop into the frame on a 2013, bog standard 45° 1.5 inch cartridge for the bottom and a 45° 1 1/8th on the top, dimensions below, or go and ask Adam next time you’re in BS 😉
Upper bearing OD=42 x ID=30 x A=45° (for 28.6mm / 1 1/8th upper steerer)
Lower bearing OD=52 x ID=40 x A=45° (for 38.1mm / 1.5 lower steerer)*
*assuming you’re going to use a tapered fork, if you want to use normal you’ll need
for future ref, this headset finder tool on cane creek website is useful
If you don’t have the crown race and upper assembly and need a full headset then look for one that uses the above bearings.
