It’s been a week of frustration, but seeing as I have fixed the problem I had, I thought I’d post up the resolution to close out this topic on a happy note.
Top line summary: A good example of a misdiagnosed problem
The reason the expander bolt was slipping was simply because I was tightening the pre-load bolt too much. Effectively pulling the expander bolt out of the steerer tube. I did replace it with the Colnago one, which is 90mm long and offers good support to the tube, but that didn’t make a difference.
So why was the headset still loose and causing juddering when using the front brake? Basically, the headset wasn’t loose. My LBS confirmed that I’d set it up correctly.
So I figured the headset may be damaged. The expander ring didn’t appear to be a snug fit inside the bearing or around the steerer tube. I replaced the headset, but that made no difference either.
Brake callipers and disks were tight, so I couldn’t see a problem there, but I was wrong. The disks are of the wavy variety and the contact surface with the pads varied as the disk rotated. This was exacerbated on the front as I’d used the supplied spacers (5mm) as per Hayes instructions, which was reducing the contact area with the disk further. The pads on the front were worn unevenly, with more pad remaining on the top edge. When I swapped the pads over (front to back) I noticed the rear wheel braking was very juddery too. Fresh pads solved the problem.
It may be sufficient to have removed the spacer, but I’m going to get some round rotors, as once the new pads start to wear I guess the problem will return. Why are rotors wavy anyway?
Happy to have a solution. Less happy that I didn’t diagnose it sooner. Another thing to mark down as a lesson learned and move on 🙂
