Once the British Empire had been forgotten all the standardised components were thrown out with the dishwater. Now we have at least 6 different headset standards – some of which have almost discernable differnece excpet that they won’t fit the other one.
You need to find out whether you have a Integrated/ Hiddenset/ Internal/ etc
Taken from the FSA guide to headsets:
What is meant by threaded, threadless, internal, and integrated headsets?
-Threaded headset cups press directly into the frame. The fork used for threaded headsets is threaded, and a large nut installed on the steerer tube is used to preload the bearings.
-Threadless headset cups also mount directly into the frame, but a star-nut or similar compression device installed in the fork is used to preload the bearings.
-Internal headsets are functionally similar to threadless headsets. The main difference is that internal cups press almost completely into the frame. These are often preferred for their low stack height and clean look.
-Integrated headsets are becoming more and more popular. With integrated headsets, a bearing (usually a sealed cartridge unit) s directly into the frame eliminating the need for cups. With integrated headsets, it is not necessary to press cups into your frame, but it is important that the headtube be professionally machined to the proper dimensions to ensure smooth operation.
What are the most widely accepted standards of integrated headsets?
While there are many standards out there, the three most widely accepted are the Cane Creek, the Campagnolo, and the TH standard. All three use angular contact bearings (ACB) which we find to be best suited to handle the loads to which a headset is subjected. Each bearing uses its own proprietary ACB standard and are of different dimensions. The bearings are not cross compatible. Cane Creek Standard integrated headsets use a 35°x45° angular contact bearing (blue seal), Campagnolo a 45°x45° ACB (yellow seal), and TH a 36°x36° bearing (red seal).
