It turns out I’ve had a slight knocking in the upper cup of my headset (found by a bike shop mechanic). Apparently it was fairly minimal and probably not enough to cause any harm but I’m a bit annoyed as I thought I was okay at adjusting them (although it’s a relatively new build and the headset might have settle over time with riding).
I’ve always used the standard “apply front brake and rock the bike” approach to taking out play but do struggle when any play or knocking is minimal, telling it from a bit of play in the fork bushing or perhaps pads moving slightly in the front brake calliper
The mechanic today put his knee against the wheel and pulled against the seattube which isn’t something I’d seen before.
I was wondering what the best approach is for picking up slight play in a headset.
