I acquired a set of Hayes Stroker Ryde brakes a couple of years ago minus the hose connections.
I am now getting round to putting them together and checking what I need.
Firstly, are all hydraulic hoses a universal diamter? The hoses I have are Hope hoses, not Hayes ones. Does this make a difference in the type of compression fittings I need?
I see that CRC have the brass olive/compression fittings for Hayes brakes. I reckon I need four of these.
Is this the same thing as referred to on the Hayes website as ‘Hose insert/compression fitting’?
Secondly, what are the hose nuts? Do these screw into the cylinder and calliper and the olive then is screwed in turn inside these?
Thirdly, according to the Hayes website I will need 2 nose cones (the calliper end doesn’t need one – is this correct?)so only one for each cable/cylinder junction?
Finally, is it easy enough to put it all together? (I got a bleed kit from the fella who sold me the brakes so just need some fluid and away we go)
Sorry if obvious questions but don’t want to buy the wrong things or have to buy full Hayes hose kits.
