hi,
Looking for a bit of advice on a hayes brake calliper. I lent my bike to a friend and got it back today after a few months. When i pulled the rear brake leaver it went straight to the bar, i heard the noise of fluid squelching out.
On looking closer at the brakes i noticed that the allen screws holding the two parts of the calliper housing together had worked loose. The paint on the callipers is badly corroded and brake fluid everywhere.
Im guessing the pads are goosed, there was loads of gunge in and around the pistons. Ive cleaned it off as best as i Can and put the calliper housing back together.
The two halves dont quite seem to meet as expected.
Are my brakes knackered? If its unlikely then Ill get the bleed kit and give it a shot. If they are past it ill have to get some new ones 🙁
cheers
