just stripped my other bike down.
the forks are tora 318 air (with poploc) bought from merlin in 2009. on the bottom of one leg there the black plastic cap for the rebound adjustment (same leg as the poploc connection)... on the other leg where the air spring is located (with the air valve at the top) there is a threaded hole but no bolt in it (there is what looks like a valve hidden a few inches up the fork leg).
is there supposed to be a bolt in there and if so, does it do anything other than protect the valve that is hidden up there?
the forks seem to work fine as they are right now
thanks
yes you are missing a bolt
