Doesn’t seem to fit although I am sure I have seen fluxes with these headsets on before. I have normally had integrated headsets, but this one needs a headset press right? (Stupid question I guess, but help me out, this type is of headset new to me). I guess if it needs a headset press its to the bike shop with it, unless there are any bodges? 🙂
Also it comes with one of those expansion bolt jobbies that I thought were for carbon steerers, but my (non carbon) forks have got a star nut in them. Can I just screw the bolt and top cap into the star nut or should I hammer the star nut in and use the expansion bolt? I trust the star nut more than one of those expansion bolts TBH
Any advice appreciated. Its only easy if you know how right?
You could probably fudge a headset press with those free weights on your floor. Or a hammer and a lump of wood. Or take it to a shop to be done properly. Headset looks right though.
I made a press with some big washers and a length of threaded rod, but it can be a pain getting the headset in straight if its a bit tight, patience is definitely a virtue.
Not what you mean about not trusting the expansion bolt, what’s not to trust? its only there to apply the minimal of pressure while you tighten the headset bolts.
But in an expensive frame if I hadn’t done one before I would just get a shop to do it.
And yes, the top cap is only used to pre-load (lightly) the headset and as soon as the stem bolts are done up it has no more function other than filling a hole. Do not really tighten up the top cap bolt as it will put too much load on the bearings and with the Hope ones the bolt will snap as it is aluminium.
my forks are already trimmed, went through that trauma and probably similar post of stupid questions on here lat year 🙂
I so want to bodge the headset on tonight so I can get the forks on, but I think I will take to local bike shop in the morning. This will be my last bike build for a very long time as the Flux and my crosslight are all I will ever need so buying a headset press isnt an option.
Firstly my wooden headset press doesn’t have a name and secondly it is only 1.5ft long now as the other 0.5 is used as a support block for the opposite end of the headtube. 😳
Sticking the cups in the freezer can help get them started in the absence of a press, they are so lightweight though that you have to be quick before they warm up. My ex was resigned to the freezer and the oven being used to ease MX parts together, or maybe that’s why I’m the ex…
me too but Ive got nowhere to put it, got about 4 pallets and some off cuts from my joiner friend to chop up. This lot should see me through next winter though!
It may be me or just the picture but those forks don’t look as though they are sitting correctly in the bottom headset cup and the top headset cup doesn’t look as though it’s in as far as it will go .
