Yeah they’re better than most others and am setting them up properly.
Admittedly used compressionless cables on the BB5s which gives a crisper feel.
Though I don’t mind a slightly spongy brake lever that pulls in further as I’ve small hands. It’s more that a good set up doesn’t seem to last very long compared to the BB5s, which respond well to winding the inner pad in and using the barrel adjuster to compensate for pad wear. I don’t really think the adjustable outer pad adds much over a barrel adjuster.
Haven’t used the MTB ones but the road ones didn’t cope very well with wet and gritty touring – small bits of grit seemed to interfere with the pad holding spring to the point that it got mangled and needed replacing roadside. The Shimano style retention pin would have helped avoid this I reckon.
May recable with compressionless and get rid of the inline barrel adjusters before I whinge about them any more!
