Then its hardly a great comparison saying you saved loads of weight going from a coil fork to an air fork.
It is, if you’re getting comparable performance, which most accounts say you do (mine are still in the box). Coil isn’t a good thing in itself, it’s all about the results (having said that my air-sprung lyrik wasn’t far off the performance of the coil either, til it exploded while dealing with the dizzying stresses of sitting in the garage)
My hardtail has a set of Revelations in it. They weigh pretty much the same as a set of 160mm Pikes. That’s crazy talk. The weight difference from coil to air lyrik is much smaller than the difference from air lyrik to Pike.
