Razor has a nice heft to it also is shiny, so remains to be seen if that equates to slippery. Came with 5 extra value cartridges and the red hinged cartridge “cover” you see on the left.
I went with FFS for my legs for a while. Found that the hefty metal handle made it more likely to break the blades if it got dropped in the shower. Decided to get a razorpit and use some old gillette blades I found in the other bathroom and have saved myself a load of money with zero change in performance.
It does. I had no issues at all with Mach 3’s so unless a wondrous shaving outcome happens I too shall be ordering those from Amazon when the Cornerstone ones run out.
cornerstone have been the worst cartridges ive ever used for clogging. tried one for ‘quick-shave’ work purposes, but i dont think ive had one pleasant experience with it.
You know the way some of us are really into bikes? Well my dad is really into shaving stuff. Has tried them all and has a vast collecting of blades from all over the world. Buys his soap/gel/foam/lotion from all over the globe and has them neatly presented in the bathroom in order of the world’s best, 2nd best etc. Spends a fortune on this pre-shave stuff but swears the cheap double blade razors are the best. Has various grades of denim strips (i bring him round my old jeans) cut to clean them after – with the blade direction obvs. Says doing this makes then last for months of daily use.
He’s 80 but has the face (the bit you shave anyway) of a 30yr old. Makes me feel his face every time i call round 😆
Ive started using Harrys razors, they have recently changed the design of the blade and now have the back bit as well. I’ve found them very comfortable and give a good shave. If used with a razor pit they are lasting for ages too. Im pretty pleased.
Those Cornerstone ones say
Please note, although our razors are perfect for your face, we do not recommend using them for head-shaving.
I gave up on the Harry’s blades after a 6 months perseverance.
The blade was to aggressive and made my face feel irritated. Also the back blade (for below nose) would cut me when using the first 3-4 times with a new cartridge.
DE razor for me after trying all sorts over the years.
I get bad ingrowing hairs and a very irritated neck which stopped as soon as I started using a DE razor.
I think it’s because the shave isn’t quite as close.
I tried a variety pack of blades and settled on the Wilkinson Sword ones. I think a pack of 50 cost me about £8.
As I’m spotting a short boxed style beard currently, I used the back precision blade. to clean up the edges I’ve never used one before – bear that in mind. Overall I think the Cornerstone gives me a smoother shave than Gillette after the first pass. Under my chin/neck I normally have to reverse pass (shave upward) to get smooth there.
Sharp Gillettes also feel precarious around my Adams apple too, and I often nick myself with a new cartridge – not so with the Cornerstone.
I’ve some slight redness at the lower edges of my beard, but thats the area I used the precision/back blade. Next time I’ll avoid it and use the normal side as I would with the Mach 3 and see if that reduces it.
I am slightly disappointed there wasn’t a load of claret on the carpet ….;-)
Doesn’t it twist your lemon ,when one’s partner shaves their bits with a cartridge you have used only once?!
