Viewing 3 posts - 1 through 3 (of 3 total)
  • Hanging/suspended shelving
  • core
    Need a shelf in our kitchen, only available wall is stud/plasterboard, with sparse studs & slightly shitty board, however, there are some decent beams above, so was thinking that would be an option, but can’t find much suitable.
    I can make a timber shelf easily enough, just need wires/brackets/fixings, any ideas/past experiences to share?
    bforbertie
    Have used threaded rod + bolts/washers to suspend a computer shelf below a desk, if you can get it long enough and don’t mind the slightly engineering look, it works well, and infinitely adjustable!
    BigJohn
    Chunky rope through holes drilled in reclaimed planks with figure of 8 knots under the planks
The topic ‘Hanging/suspended shelving’ is closed to new replies.
