thought about tubeless……is it that good?
It certainly reduces incidence in my experience:
* Thorn prick type punctures often self-seal. You may not notice – or the tyre may soften then seal, you investigate and just add some more air.
* Snake bites are rarer.
* Tyre slashes can often be repaired with a TL repair kit, without taking the tyre off or the wheel out of the frame even.
If all the above fail, just whack a tube in, which is no bigger a deal than fixing a tube flat. (But make sure you check the inside of the tyre for thorns that may have self-sealed, but are still there so would flat a new tube on inflation).
Caveat: some tyres can be very tight on tubeless rims. I wouldn’t run a tyre that I couldn’t get off the rim trailside.
A search will show up gazillions of threads on this.
