Of course it depends what you ride and how you ride it, and how you are built (shoulder width, arm length etc)
But i’d say, try it, you might like it!
One thing i really noticed on a swap from a 75mm stem/690mm bar combo to a 50mm stem/750mm bar combo was that not only was there more “leverage” but the higher moment of inertia caused by your heavy hands and upper arms being pushed out further from the center of rotation mean’t a lot more stability too in the choppy stuff! (kinda like a steering damper!)
When pushing hard into flat and bermed turns, that moment as you feel for front end grip and the handlebar turning loads sort of reverse a bit(as the tyres loads/slips) seem to be a lot easier to feel and “ride through” with the wider set up, and the front wheel felt a lot less likely to “tuck under” quickly.
