I think that it will, but with a couple of caveats*.
* You need the 135 front, 170 rear both set up for quick release skewers.
But there are 2 different 135 mm front hub/fork standards. The Fatty uses a front specific spacing for the front hub & disc rotor. The other standard uses the same spacing as a regular 135 mm rear mtb hub. I couldn’t see which the Halo was.
* You may get chain rub if you are 2×10 due to the wider rim.
My Fatty (Raceface/Shimano 2×10, On-One wheels) has less than 1/4 inch clearance between the tire (Floater) and chain when on the innermost gear combo. The Halo rim is 10 mm wider, so would move the tire out 5 mm or so. And if you are using a different tire…
EDIT – The On-One website says that their wheels/forks use the 135 mm rear disc spacing on the front. But I’ve tried putting a regular 135 mm rear wheel on my Fatty (to fit it in a bike rack) and the rotor fouled the disc caliper. Thus I thought it was the fron specific spacing. I am confused… 😥
