“Black” is closed, has been for ages
Blue is ok as long as you hit the whole thing at a sprint to make the flat corners sketchy.
Red is ok, shrugs.
Great trail center for local families, not for Gnarcore
The off piste stuff is better.
can you see this route?:
https://www.strava.com/activities/646641636
Head up to the “bird of prey” viewpoint, and head off the end of the hill into the bushes. Two obvious routes become maybe 4 options over that side.
Keep an eye out for turns off the blue too, they are nearly all cheeky descents.
How much time have you got?
spend another 10 mins on the road and you can be in Bovey tracey to hit the MBR nutcracker loop, which is a much better use of time.
Also, the quants are v good too. Probably getting on for an hour from honiton though, by the time youve wiggled through the lanes
