H Bar stem
[Closed] H Bar stem
[#2294048]
What stem do I need to give me the same bar position as I have now, but on a H bar?
Current stem is 95 x 12°
Posted : 17/12/2010 11:11 pm
Anyone?
Posted : 22/12/2010 10:52 am
Ive gone from a 70mm to 100mm and seems to be about the same.
I was told adding 30mmm-40mm is around the sweet spot.
Posted : 22/12/2010 10:56 am
What about rise?
Posted : 22/12/2010 11:01 am
I'd say a 120x20ish.
Posted : 22/12/2010 11:03 am
Use 130mm stems with mine.
Try it and see, some advice on Jeffs site I believe.
J.
Posted : 22/12/2010 11:20 am
bonesetter - Member
What about rise?
10* only because I had it lying around... 🙂
Oh, and I put another 3mm spacer under my stem too...
Apologies for the crappy iPhone pics, but you get the idea...
Posted : 22/12/2010 12:21 pm
doesn't Jeff say to go with what you already use?
Posted : 22/12/2010 1:17 pm
I added 20-25mm of spacers and the same in stem length on my bike. there's a drop to H-bars when set at a comfy angle, i/o most bars having 20mm ish of rise.
Posted : 22/12/2010 2:17 pm
I've gone from 90 to 70mm
Posted : 22/12/2010 4:02 pm
Were you using a flat bar before or risers?
Posted : 22/12/2010 4:19 pm
bonesetter - Member
Risers...
Posted : 22/12/2010 4:43 pm
New loop H bar or old H Bar?
What bar you replacing?
Posted : 22/12/2010 4:56 pm
Stu - It's a JJ H bar (not loop, so presume 'old') and I'm going from a med to highish riser bar
Posted : 22/12/2010 11:45 pm
In that case you're going to need an upright cattle prod. 😉
Posted : 23/12/2010 10:28 am
😆 Thought so 😆
The (slightly) more full story is the ByStickle will have a taller HT which should make the bar possible to use on
The SS rigid coming is less likely to fit, which is a pity as this is one is best suited
Posted : 23/12/2010 10:47 am
