Viewing 3 posts - 1 through 3 (of 3 total)
  • Guide Ultimate stealthamajig…
  • panzerjager
    What are my chances of shortening my guide hoses without needing to bleed them?
    Anyone have experience of this?
    I managed to route my stealth reverb without the need for a bleed & I’m pretty sure the ultimates use a similar stealthamajig at the lever end, but I can’t seem to find a definitive answer.
    Do they all have it & if so, is the factory fitted one reusable, or will i have to buy the barb etc anyway.
    Not being a cheapskate, I have a bleed kit for my older Avids but can’t get the ‘bleeding edge’ adaptor locally.
    Cheers for any help.
    pigyn
    You need a stealthamajig barb and olive, the levers specify only these, and you can’t re-use the olive.
    You won’t need to do a full bleed just purge the lever
    panzerjager
    Thanks, I’ve just checked my levers & they’re not printed ‘stealth-a-majig only’ as the online manuals say.
    Does that mean they’re not & I can only use the standard type barbs?
    & presumably purging the lever just involves sucking the air from the lever port but the calliper remains closed, yes?
    Thanks again.
The topic ‘Guide Ultimate stealthamajig…’ is closed to new replies.
