Viewing 16 posts - 1 through 16 (of 16 total)
  • GT85 – Recommend me an alternative!
  • abbot
    Ahoy!
    I’m a big fan of GT85 but I wondered if there were any alternatives I should consider.
    Anything cheaper but as effective would be fantastic!
    dannybgoode
    Is it really worth saving a £1 or so a can – doubt you’d find anything cheaper than £2 (unless you’re getting through unhealthy amounts of it).
    I know it works so I use it…
    Danny B
    esselgruntfuttock
    I like that stuff in the green can cos it smells better.
    rossi46
    Yoshimoto No Rust O Preen
    It’s awesome 😉
    st
    WD40 if you’re happy just to have water displacer without the Teflon
    watsontony
    wd 40 to clean. and different types of grease for lube
    scaredypants
    WTFOMG no way – yoshimoto no rust o preen exists !
    abbot
    Looks like GT85 is the winner then. Glad I can stick with what i lov, or not as it’s teflon
    Northwind
    TF2 spray seems to be much the same.
    I used to go through cans of No-Rust-O-Preen like my dad goes through cans of belhaven 😆 Not sure it’s actually any good. Does it “dissolve rust”? Does it balls. If it did, my Virago would have run down the drain.
    rossi46
    Never used it on my motorcycle- i stick with WD40 for that (cheaper, smells nice), but iv’e used it to lube my MTB chain and squirting out gear cables etc for years. Works really well for me, it never picks up dirt and dosen’t wash off in mud too easily. Although if a filthy ride is on the cards i’ll chuck some Finish Line on.
    barn
    GT85 in ‘trigger spray’ 1l works out cheaper and less packaging waste.
    Linky
    godzilla
    Duck oil, cheaper betterer and go’s further 5L has lasted me 5 years, i use it on loads of stuff.
    Conan257
    Stick with GT85, not only does it work well on the bike, but can replace Lynx spray and aftershave!
    gamo
    Wurth ultra 2040 is the biz!
    rossi46
    Job done 😆
    perthmtb
    I was wondering the same thing just a few days back. Wanted to get some GT-85 but couldn’t find any locally. Everyone seemed to have this instead…
    Which looks like the WD40 brand equivalent of GT-85 – is it?
The topic ‘GT85 – Recommend me an alternative!’ is closed to new replies.
