But it will work if you know that you never use cross over gears.
You’re prepared to run the risk of an accidental shift, or someone else taking your bike for a spin round the carpark, resulting in total destruction of the rear mech and/or worse, the mech hanger on the frame? 😕
Right tools for the right job methinks is in order…
Can use a shorter cage mech if you’re only running 1 or 2 chainrings, if you’re running a triple (especially with a wide ratio cassette such as the 11-36) you need a long cage mech to counter for the massive differences in chain tension experienced.
