You know those days where you wish you hadn’t started fiddling?
Well after a bit of a wait for hope headsets to come back into stock by new HX1 arrived today, all good so far.
Now, this is one of those builds where you rationalise it by owning 1 part and figuring that you may as well buy some other stuff to use it? Well this build started with the forks and wheel off my Pitch, the forks are OK and but the rear wheel’s pretty crap so figured I may as well build them into something and kill the wheels off before upgrading them at a later date, so really it’s just the forks (can you see where this is going yet?).
They’re 10mm (at least) too short! Despite going from an externally cupped straight headtube to an internally cupped tapered one they don’t fit!
Garrrrrr humbug.
So I decided I may as well bleed the rear elixir on the pitch whilst I’m out in the garage having just unearthed the bleed kit I thought was lost.
Bleed screws out, syringes full of fluid in, pump in, pump out, shake them all about, de-gas the fluid’s what bleeding elixirs is all about, you do the hokey cockey and and you flush the air out…………
Syringe off at the calliper end, flush a smidge of fluid through form the other, screw back in, done. Just the screw in the lever to go, screw on the end of the torx key, unscrew syringe, WTF!!!!!! where’s the screw gone, it was there literally a split second ago. So now I have a set of buggered elixirs and a new bike with no forks, f***sticks!
Anyone got either the bleed screw for an elixir or some long steered sektors/revelations? You might even have some tapered ones and you need straight ones? Anyone????????? Maybe you’re just about to cut the steerer on some box fresh ones to about 190mm and you’re feeling generous?
