I think I have a piece of grit or gravel lodged on the inside of my last joint on my ring finger. I can’t remember it going in, it could have been years ago, but I can see [lighting dependant] a dark object, feel a bump and it hurts when pressed. At a guess it’s about 1-2mm diameter.
See pic:
No you can’t really see it but you’re going to have to believe me it’s there.
I’m probably just becoming aware of it now as I have been doing a little darksiding and when I use the hood braking position I have to squeeze with this part and it’s started to hurt! It’s right against a bone or something 🙁
What should I do? I am doing a sponsored ride on a road bike in 4 weeks and I am worried it’s going to be really painful, and I’m also worried that if I go to the docs it’s going to take longer than that just to get it assessed, let alone cut out!
Any ideas? I don’t fancy trying to cut it out as it’s a really delicate part with lots of important/moving/nerve bits. Oh and also last time I tried this sort of thing I ended-up slicing into a vein thinking it was trapped dirt after a nasty road off. “NEVER AGAIN” I swore, as I bled profusely…..
I had something similar with a snapped off rose thorn, it was below the level of skin that grows and gets shed so never moved. If I picked something up or gripped wrong it dug in and hurt like hell.
In the end I just kept digging at it with a needle until I’d make a hole big enough to hook the thing out. I stopped if it started bleeding because I couldn’t see what I was doing but once it had healed a bit I kept going deeper each time. It took a few weeks but I ended up with a deep enough hole to get the thing out. The scar’s mostly gone now…
I’ve got the same thing right on the tip of a finger. Yeah, it bloody does hurt when you tap your finger or something. I don’t know what the thing is in my finger but I got it from a nasty electric shock when I was trying to fix an amplifier. Probably a lump of carbonised FLESH. Feels like it’s right near the bone though so I’m not gonna start digging at it.
You could try a bread poultice, old fashioned remedy but it works a treat. Next stage up is sugar and soap, or if you need to go nuclear, Mag Sulph paste.
Use a sharp blade to slice a clean cut down to it. That’s how I get out deep splinters (though TBH that looks a bit deeper than most splinters). Perhaps surprisingly, it doesn’t usually hurt. But don’t blame me if you try and it does!
Bit of a finger tip isn’t that important – I wouldn’t worry about doing serious damage unless you are really hacking away.
