Viewing 8 posts - 1 through 8 (of 8 total)
  • Granulated/Crumbed rubber paint?!
  • spooky_b329
    I've got a horsebox that needs the ramp recovering…currently covered in thin ribbed rubber with ally strips to prevent the horse skidding down it.
    My options seem to be limited to paying £80-100 for some purpose made thick heavy duty rubber with raised ridges moulded into it that would replace the ally strips, but it will add around 80-100kg to the ramps weight and then I won't be able to lift it! The ramp is perfectly balanced at the moment…
    Someone has said they used granulated rubber paint on theirs…just slap it on and it gives a rubberised stippled finish. I can't find details anywhere. The closest I've come is a boating forum where people are talking about something similar that they can paint onto decks as a non-slip surface. There was even mention of mixing raw crumbed rubber into an existing paint, but I wouldn't know where to start…
    Can anyone help me out?!
    0303062650
    Put sand in the paint and roller it on!
    spooky_b329
    Thanks Tazzy…replace Granulated with Granular I'm sorted 🙂
    Shows it painted on a tail lift so looks like it will be able to cope with a horse stamping all over it 🙂
    vdubber67
    You can buy rubberised paint. We made it where I used to work. Essentially it's rubber dissolved in solvents with paint added. We used to sell it as a protective coating for the aerospace industry (ie it's expensive and not readily available)
    You can buy non slip type paint for metal fire escapes too. Joking aside it is a bit like sand mixed with paint. Only really prevents against slipping in the wet though.
    Rubber boots for the horse?
    vdubber67
    lol…slow typing from me there
    scaredypants
    car mats screwed down ?
    I bet Aldidl/wilkos do em
    takisawa2
    I knew I should have followed up my Rubber Horse Shoe idea.
The topic ‘Granulated/Crumbed rubber paint?!’ is closed to new replies.
