where is it located – we dont have any smell from ours – but its in a windy location – our old WB units at 2 rentals we were in both smelt bad during and slightly after use
with our grant we had a heap of issues with the flexy hose from the rigid copper pipe to the fuel inlet – turned out they had given us the wrong threaded flexy – you have to get the specific grant one apparently if your using a tiger loop and need the bypass.
take the front service cover off and look towards the bottom left – see if there are any pools of oil around.
also its possible to get a leak between the copper and the plastic sheaf if they have bent too sharply or too many times.
