2nd hand lancer, there is a gsr always for sale – although I’d often go with the prelude si for a challenge.
My shopping list was always:
ecu
stage 1 lighter
sports suspension
medium tyres (highest grade typ you can race with)
stage 1 turbo
can’t remember if 2 had downforce or racing mod, go for racing mod if you can, but downforce is important.
up rated brakes
gearbox – all singing version, adjust the gear box to ignore 1st and stretch 2nd, on a high speed course stretch top gear.
lighter 2
It’s all set up to keep the speed, set the suspension as low and as hard as it will go with 2.4 wheel angle back and about 2.2 at the front (if you set more at the front it’ll turn quicker but grip less). Set the downforce for max.
That set up will allow you to draft cars with more power and destroy them in the bends.
I wouldn’t uprate the car much past this, as you will then be going for specfic cars for each race. All out power is a bit crap if for 90% of the race it’s useless (ie speed12, but that is stunning in a straight line).
You’ll find the skyline is a bit limited, too top heavy and typical 4wd understeer, tvr’s are very good for cheap and fast racing as are supra’s.
mx5 is too underpowered but drives v nice as are nsx’s.
for ff racing get an eclipse or a integra.
I can’t remember exactly, but for either 1 or 2 there were a number of cars as prizes and depending on what you raced in depended on the car you got.
I might dig it out and have a play, gt5 forces you to grind which is a pita – 4 is cool and i adore it.
