Viewing 5 posts - 1 through 5 (of 5 total)
  • Gopro Vibration.
  • exiger
    Hi got a GoPro HD2 the other week and took it over to Haldon last weekend to try it out with the chest mount but seemed to get a lot of vibration, i know its not going to be rock steady but has anyone got any tips for keeping it a bit more steady, and just generally better quality.
    Oh and yes the straps did get done up tight.
    Shot in 720p/50fps and mounted upside down on the chest mount if thats any help.
    faz083
    have you got the anti vibration white plug? For me, it removed most of the vibration and clicking.
    DickBarton
    Tighten everything up…then tighten again. Won’t remove all but most.
    gravity-slave
    As above, or a couple of layers of insulation tape on the base plate to take up the little bit of slack, just holds it tight and stops the high frequency rattle type vibration.
    exiger
    Thanks guys will try the suggestions. Faz i wondered what that was for, i guess i should read the instructions first lol…
The topic ‘Gopro Vibration.’ is closed to new replies.
