right… i’ve bitten the bullet and ordered a replacement e-type ES51 from wiggle for the princely sum of £35 (they seemed to be the only place to have them in stock.
this should hopefull bring the chainline back to the 5th sprocket and the chain device clear of the chain (without having to use spacers)
if i was smart, i would bit the bullet in a slightly bigger fashion and replace the bb and the crankset with something a little more abundant (rather than the now-dropped octalink concept) which will become more and more difficult to source over time.
to really make things more unique, i have also cancelled my order for a e*thirteen 35t g-ring to go on my 175mm deore lx cranks (which have the granny ring tabs ground off) and have now ordered a blackspire 5-bolt 34t ring to go with a set of 170mm blackspire cranks i had knocking around the place… they are slightly heavier (by about 100g) than the surprisingly light lx hollowtech cranks, but should suffer zero flex, which once i’m up out of the saddle and climbing, should outweigh the weight disadvantage.
all good fun! (if not expensive)
i’m now at approx £570 all-in for the build which reads as follows:-
2002/3 Cannondale Caad 5 frame (F900 SL) – very light indeed)
2004(ish) MX Comp oil forks (surprisingly light)
Deore XT hubs on Mavic 717 Disc rims
Continental Speed King tyres
Deore XTR rear mech (older style) with KCNC gold jockey wheels
Deore XT 9-speed shifter with new XT-spec cable
Avid Juicy 5’s with gold 160mm Alligator rotors and Clarks sintered pads
Blackspire 5-bolt octalink freeride cranks (170mm)
Blackspire 34t single-speed chain ring
Gold cranks bolts (shallow!)
Superstar XCR upepr chain device
SRAM 11-34 9-speed cassette with SRAM 9-speed chain
Gold cassette lock ring (shallow)
Halo allen-key skewers
FSA carbon riser bars
Superstar lock-on grips (brown/gold)
Easton EA50 stem (110mm 6-degs rise)
Gold headset cap (shallow!)
FSA carbon seatpost
Charge spoon saddle (brown)
phew… just hope it works
i reckon it’s cost me more to go 1×9 on this bloody thing than if i had just bought a SLX groupset from that shop in Germany and got 30 speed!
