Feel like giving this tubeless thang a go.
why? – it’s not a weight saver, and there are drawbacks.
How much sealant is needed per tyre? I will be using 2.0” tyres.
something like 100ml’s – maybe a bit less. maybe a bit more if the tyres aren’t pre-sealed. (you need some to seal the tyre walls, and then some more sloshing around inside to seal any punctures)
buy some extra, you may end up trying several times as you work towards a solution.
sacrifice some livestock to your favourite gods, send any children away so they can’t hear you swearing.
buy some ear-plugs, you’ll need them when your home-made compressor explodes…
don’t do it on a friday night, it won’t work, and you’ll be at risk of ruining your ride on saturday.
