Viewing 6 posts - 1 through 6 (of 6 total)
  • Going to do a bit of road stuff – is a hybrid frame OK?
  • sharkbait
    Looks like I’m going to be doing a bit of road riding this year (with MTB buddies who already do a bit of road). There’s def no racing involved (usual rides maybe 30 miles) but I think there is a plan to do one 100 mile ride in the summer.
    I’m on a tight budget and was wondering if I could also be looking at used hybrids (with drops fitted instead of flats) as well as racers? How different would a hybrid frame be?
    cynic-al
    Will work fine but having to add drops is expensive. Plenty cheap road bikes on ebay no?
    The main difference is gearing and light, narrow tyres – you’d be OK with a hardtail and spare wheels.
    pixelmix
    I suspect you would find that hybrids tend to have a slightly more upright geometry (so less aerodynamic) and slightly heavier frames. This won’t be a problem on most rides, but will slow you down a bit on a 100 mile ride I would imagine. If you discover that you have to spend money on new bars/stem etc, you might be better just buying a road bike in the first place.
    There are some “fast hybrids” which blur the lines a bit though.
    sharkbait
    Re the fitting of drops, I do have an option of a pretty good bike already fitted with drops so no expense there.
    cynic-al
    Aero position will matter according to speed, not distance, cumlative effect will of course be greater on longer rides.
    SB sounds like a good option if it’s a hybrid then you may find the jumps between gears quite big, but you’ll be able to fit a closer ratio cassette and narrower tyres if you get that into it.
    paulosoxo
    Carrera usually have a quick hybrid in their line up. The used to do a Gryphon, which literally was a flat bared road bike.
    Putting drops on flat bar bikes is an expensive upgrade also. The top tube is shorter on a true roadie.
The topic ‘Going to do a bit of road stuff – is a hybrid frame OK?’ is closed to new replies.
