Your chainrings only need to be 10speed specific if you’re changing between rings, i.e. if you’re on a 2×10 or 3×10 system. For 1×10 you can use any ring you want, ramped, unramped, anodized pink etc.
If you’re pretty much sticking to riding off road then most likely a 32t ring will give you a more than big enough gear with an 11t sprocket. You’ll spin out at around 20mph with that gear.
If you are very fit (like Njee) and ride a lot on roads to get places, then that might be a bit limiting, but off road, I would be surprised if you’re ever spun out at 20mph. At that speed, you may be as effecient to tuck into an aero position and carry speed rather than pedal.
I’m actually running a 32t front with 11-36 rear and am on a short cage SRAM mech. If I was setting up again I would most likely go medium cage SRAM as the chain tension on the 36t rear can be a little high.
