Viewing 23 posts - 1 through 23 (of 23 total)
  • Give me a STW health diagnosis – Random choking
  • FunkyDunc
    Ok, firstly I never normally say go and see your GP in response to these types of threads, but I am curious to see if any one has ever had similar…
    This has been happening infrequently for probably 3 months or so now. For no apparent reson ie no pattern I may all of a sudden get a feeling that my throat has completely closed of, no warning, nothing leading up to it. It last for a few seconds and then goes but my throat feels bruised afterwards.
    Last week it got to another level where I woke up in the night and was unable to breath for a matter of minutes, it felt like 5, but I am sure in reality would have been a lot less.
    Next day went to the docs, and Im put on Asthma inhalers etc as I was queried Asthmatic after a bout of Pneumonia last year. I’m happy that he is treating me as such. Peak flow was reduced to 525 from an Avergae of 620. Peak flow is currently about the 600 mark
    Anyhow since then the choking attacks have continued. All completely random, only last a few seconds but still very frightening, especially doing 70mph in the outside lane of the M1!
    Has any one had any similar experience and what caused it? I’ve read about GERD and the symptoms do seem very similar, but I was just wondering if any one else has had these similar experiences?
    Ta
    allthegear
    can I have your bike??
    thegreatape
    Are you eating when this happens?
    FunkyDunc
    No not eating, as I say its completely random.
    When it happens its scary so forget to think what the symptoms were before, but tends to be (I think) after I have yawned or swallowed.
    Allthegear – Its not killed me yet 😕
    donsimon
    muddy_bum
    Whooping Cough
    donsimon
    More seriously stress or anxiety?
    TheSouthernYeti
    Are you a fluffer?
    martinhutch
    By throat, do you mean airway or higher up ie do you feel like you’re properly choking, gagging or just can’t breathe?
    The closest fit for what you’ve described is some kind of muscle spasm in your aesophagus, but as to the root cause, you’d need some further investigation, so the usual advice applies.
    I used (and still occasionally) wake up with a form of night terror in which I’m convinced I’m choking, but that doesn’t completely fit.
    Most likely, as DS says, someone is hurting your daemon. Mine takes the form of a rather overweight sloth.
    qwerty
    Lube your epiglottis, beer should do it.
    bruneep
    Does mrs FD have her hands around your neck when this choking happens? This maybe the cause if she does.
    DrP
    Rubs chin..
    Hmm – have you upped your life insurance figure recently…??
    DrP
    On a more serious note – no idea. Not enough info here – go see your Doctor and tell them if it’s breathing/eating that’s affected etc etc
    FunkyDunc
    Your a synical bunch !
    I’m keeping a diary for the next couple of weeks so will note all episodes for the GP..
    I just wondered if anyone had had similar.
    Martin – By throat I mean Adams Apple area.
    donsimon
    I have- email if you want.
    FunkyDunc
    Don – I’m pretty sure its not stress or anxiety, as life is pretty dam good at the minute! 🙂
    …apart from randomly choking
    theotherjonv
    oddly, have been having similar symptoms but for me it is definitely brought on by coughing. I did idly wonder a week or so back if it was whooping cough. It’s definitely a throat thing, because if I calm down, and don’t panic, even as the coughing is continuing, i can quite easily breath through my nose instead – which to me says it’s higher up the airway than a proper choke which if I understand right would be an airway blockage.
    It is quite annoying / distressing though. Happens to me maybe 6-8 times a day, and your description of feeling ‘bruised’ in the throat after is quite a good one.
    I also saw the docs and they gave me asthma meds too, but I’m not convinved as this is all to me well above the airway – it’s a throat thing.
    donsimon
    You asked the question. 😉
    Kunstler
    I used to have the same thing happen to me but only during sleep. It’s terrifying to wake up not being able to breath and this choking made me scared to go to sleep for a while.
    Sleep Apnea
    My GP sent me to see a consultant who had me monitored while I slept and then proposed a kind of gum shield that would cause my airway to remain open. In the end, I didn’t have this done but managed to beat the problem by losing weight (I lost a fair amount). I haven’t had an episode of choking since although I do still snore a bit.
    donsimon
    Sleep Apnea
    That was one of my thoughts as I used to stop breathing at night, as I was told.
    As you say, weight is often a factor in the closing of the airway.
    theotherjonv
    how can it be sleep apnea when it’s been happening for the past 3 months and only last week became a nighttime thing?
    [if you are sleeping at 70mph on the M1, may i suggest you get that seen to before worrying about this issue ;-)]
    DrP
    It’s a different thing, sleep apnoea.
    Though, if you are sleeping at 70mph on the M1, may i suggest you get that seen to before worrying about this issue 😉 would score massively on the Epworth Sleepiness Scale…..!!!
    DrP
    therealhoops
    You got kids? croup is doing the rounds at nursery. No doubt so other lurgies are hitchin a ride as well.
    Have you tried nuking your throat with a curry? Can’t hurt to try.
    What does your uvula look like?
    therealhoops
The topic ‘Give me a STW health diagnosis – Random choking’ is closed to new replies.
