GUESS:
probably needs an oversize handlebar (31.8mm) – assuming you’re keeping the existing one
top of yr steerer tube is very likely to be inch and an eighth (28.6?)
BUT
measure both of these with a caliper if you have one or else by eye and ruler if you’re careful
measure your existing stem from centre to centre of the 2 “holes” (where it fits over steerer and where the bars pass through
shortest you can get is prob 40mm or more likely 50 but you may find that too short, esp if yr frame is L or XL
buy cheap or secondhand & try for size, then either keep or buy a bling one if you must
