Not sure if they are the exact same, but I have a 2015 Giant XTC with the SXC-2 wheelset. I went tubeless on the rear about 3 months ago and it’s been fine.
For reference I…
Removed the rim strip, cleaned around the inside of the rim, taped it up using Stans (20mm I think), replaced the tube and tire (new Maxxis Ardent), pumped up to 40 psi and left overnight.
Next day I removed the tube, leaving the tire seated on one side, chopped a valve out of an old tube, fit and refit it numerous times until I had enough PTFE around the stem to stop it leaking! Once happy that it wasn’t leaking I replaced the blue rim strip, filled with Stans, seated the tire using the tire lever and foot pump method, gave it a good shake and left over night.
Smiled in the morning when it was still up and took it for a test run 🙂
