Viewing 13 posts - 1 through 13 (of 13 total)
  • Giant Overdrive Steerer…?
  • PeterPoddy
    Mate of mine has just bought a Giant with this bizzare steerer size.
    He wants to upgrade the fork to a standard tapered steerer Fox.
    So, bottom bearing should fit OK, yeah?
    What top bearing/adaptor does he need please?
    Cheers in advance. 🙂
    Rorschach
    1&1/8th 36/45 bearing.A 1 1/8th compression ring,cover and top cap.
    PeterPoddy
    So it’s as simple as chucking a new bearing it then?
    Adam@BikeWorks
    What’s the ID of the top of the headtube?
    I’m sure Hope or Cane Creek will do a cup if its a weird size.
    IHNWOAGWOD2
    Rorschach
    It’s 44mm.They just use a bearing with a bigger I.D.
    Kryton57
    Overdrive or Overdrive 2?
    They are different.
    Adam@BikeWorks
    If it wasn’t overdrive 2 surely he wouldn’t need to ask?
    PeterPoddy
    Normal overdrive.
    That said, we’ve just had it apart and it seems to be an Overdrive head TUBE with a normal tapered steerer fork in it, so it should be a straight swap.
    Good info though chaps, thanks for that. 🙂
    Adam@BikeWorks
    Normal Overdrive is standard tapered.
    It’s only overdrive 2 that has the 1 1/4″ top to the steerer.
    PeterPoddy
    Really? Thanks for clearing up the daft confusion dude! 🙂
    Kryton57
    Yes precisely why I asked – OD is standard taper. OD2 still accepts standard taper but needs the reducer cup/bearing at the top.
    granny_ring
    So, if I understand it correctly…..
    To run an Overdrive 2 as a normal Overdrive with normal tapered forks you just replace the top cup with something like a Hope top cup?
    STATO
    yup.
The topic ‘Giant Overdrive Steerer…?’ is closed to new replies.
