Hi all,
I’m trying to fix an issue with an old Giant NRS rear shock. I have opened the air can which seems fine but the damper makes a strange grating noise as it extends and is very notchy. It also tops out with a bump when it rebounds. I suspect something is amiss in the damper or perhaps just not enough fluid?
Very hard to find info on this old shock – the best I could find was this: http://www.chetwynd.info/mtb/giant_nrs_shock_rebuild.htm
A couple of questions before I try and open the damper as the article suggests though.. I always thought rear shocks needed a nitrogen charge in the damper after the service but this article just leaves uncompressed air in the chamber by the look of it. Can this work? Its a long shot but any ideas on quantity or type of oil?
Cheers!
