My 3 month old Anthem SX is out of alignment at the back. I noticed a few weeks ago that there was a few mm less tyre clearance on the NDS seatstay but thought it was probably the tyre. I tried it the other night with wheel on and no tyre and it was still out, so tonight took the rotor off and tried wheel other way round as thought dishing could be out. No, still same. So then rechecked with a string round head tube and dropouts and measured carefully string to centre of seat tube each side and the NDS is 2.5mm closer in than DS.
Will take it to LBS who supplied it tomorrow. I’m expecting that they will likely have to strip it down and send frame to Giant UK ? for checking and then replace either the rear triangle or full frame under warranty ?
It hasn’t been crashed, or even dropped and it’s immaculate as only been ridden a dozen times max, so not anticipating any hurdles.
Anyone who has been there able to advise if this is likely approach and any ideas on possible timings ?
I’m sure I’ll get answers from shop tomorrow but keen to be as prepared as possible.
