I’ve done mine (stock rims on a Dune; same as the On One Emmenthal among others) with foam-and-split-tubes originally, but now redone with foam-and-plastic-wrap. Both work well but the plastic wrap is obviously quite a bit lighter. The foam was a wee bit of a pain, I used jiffy foam and it compressed over time so when I went to change a tyre, it wouldn’t reseal- but adding more foam seems to have fixed that.
I’m just experimenting with yet another method which I think might be the best of all worlds, foam with wide PVC tape to seal instead of the shrinkwrap. It’s probably fractionally heavier but first attempt suggests it’s easily reusable which is a big bonus.
Oh- if you do split tubes, people often recommend the schwalbe AV10D but the AV10 works just as well and is a lot lighter. It’s just barely wide enough for an 80mm rim but just barely is the perfect width tbh.
