Viewing 30 posts - 1 through 30 (of 30 total)
  • Getting into an encrypted (Android) phone?
  • thisisnotaspoon
    My old S4 is broken, screens in a bazillion bits. It turns on, but only for a minute or so and not long enough to send any pics to flickr or elsewhere, which brings me onto what I need to do.
    Can I connect to a PC and read the photos off the SD card without the phone being on? Obviously I know the passcode but can’t (AFAIK) put the card in the PC, it can only be read from the phone because it’s encrypted?
    Is there any way I can get the pics off the phone?
    Pissed off because I bought a NAS/cloud hard drive when we moved house, but it went back in it’s box while we re-decorated and I never actually backed anything up off the phone!!!!!!!!!!!!!!!! 3 years of snaps 😥
    TheFlyingOx
    I’d try this first.
    thisisnotaspoon
    Comes up as inaccessible/no data because it’s encrypted. That was my first hope.
    Anyone here work at the FBI?
    martinhutch
    You have to actively select encryption I believe, so it’s worth trying it in the pc unless you’ve definitely done this.
    EDIT: Ah.
    thisisnotaspoon
    Yep, it popped up as an option when the phone was new, so I ticked the box 🙁
    lllnorrislll
    Have you checked to see if the phone has automatically backed them up in to Google photos?
    thisisnotaspoon
    Yep, nothing like that set up 🙁
    Thinking outside the box, as I know the passcode is there some sort of phone emulator software that could read the phone/card?
    Shackleton
    Can you put the sd card into another handset and see if it will play along?
    sirromj
    I don’t know about encryption but am fairly sure Linux provides loads of tools for mounting encrypted data partitions etc.
    Might help to know if Samsung used a standard encryption method for the S4?
    Use some low level tool to make a backup of the encypted partitions so you’ve got something to experiment with without fear of losing data for good.
    santacruzsi
    Try these guys http://www.cellebrite.com 🙂
    ghostlymachine
    How long does it stay on for if you connect it up to your pc?
    I’ve “recovered” stuff that way. (Pulled it off the memory card)
    bails
    Andyroid is a free android emulator, don’t know if you could do anything with that?
    iffoverload
    the developer software might do the trick?
    https://developer.android.com/index.html
    you could try asking on the XDA forums perhaps?
    http://forum.xda-developers.com/
    Kelliesheros
    I think your in trouble. There are ways to unlock passwords using developer tools, but you would have to have enabled USB debugging before hand.
    One other way worth trying is to plug in a USB keyboard via a USB otg cable. Boot phone and enter passcode. This might sound crazy but I can plug a mouse into my phone using one and I getva little mouse pointer on my screen. Otg cables can be got on amazon for about a pound.
    nickjb
    What about getting the screen fixed? Lots of backstreet places doing it pretty cheaply. Probably not cost effective for that phone but you should get your pictures back (which you will back up straight away!) and you get a spare phone
    gofasterstripes
    fix phone>download pics*>wipe>ebay
    *the shop may do this too – what’s on it?
    thisisnotaspoon
    I can get into the phone and find the photos, the screen still works as far as that, the issue is it crashes before I can upload them to anything, I can’t figure out if it’s an app crashing it or hardware (moneys on hardware) but it always crashes and dies after about a minute.
    Pretty sure the USB part is dead too, it seems to charge fine, but appears to have an iffy connection when trying to connect to a pc. So pretty much the only way will be to do something with the SD card.
    Think that means it’s dead 🙁
    ghostlymachine
    Tried starting it in safe mode, that’ll at least establish if its hardware or software killing it.
    gofasterstripes
    Which version of Android is it on?
    thisisnotaspoon
    How do I do that?
    (5.something)
    bigyinn
    If you can get into the phone, why not just disable the encryption?
    thisisnotaspoon
    Doesn’t work backwards, encrypting turns the memory to gibberish, so the only way to un-encrypt it is to copy those files out once they’re open.
    gofasterstripes
    Software version:
    Settings/scroll to bottom
    gofasterstripes
    I was just thinking if you knew the version, maybe you can crack it over USB…but you have to switch
    DEBUG OVER USB
    on
    zzjabzz
    Would the card be readable in another S4, if you could borrow one, or is it encrypted to your phone only?
    thisisnotaspoon
    It’s done by the phone so no it can’t work like that either.
    I’ll try safe mode tonight and if that doesn’t work I think it’s probably a dead end short of having the phone repaired.
    Lesson learnt, encrypt the phone but setup a backup for photos and sentimental stuff!
    jeffl
    If they have any sense, which they will have, it will be encrypted to your phone only. Dropping it in another S4 won’t work.
    stumpy01
    thisisnotaspoon – Member
    Before it crashes, do you have a chance to do anything at all?
    If you do, then can you just uninstall all apps and see if that solves the crashing problem?
    ghostlymachine
    Or start it in safe mode so none of the apps start.
The topic ‘Getting into an encrypted (Android) phone?’ is closed to new replies.
