- This topic has 102 replies, 56 voices, and was last updated 9 years ago by mikewsmith.
Genuine Question – What's the point of 1*10 or 1*11 setups?
DaffyFull Member
Okay, I understand that there’s overlaping ratios in double and triple setups, and I understand that by removing a chainring, mech and shifter, you save a little weight, but surely by adding something like a 42t rear spocket, a massive cage rear mech, and the requirement for a chain guide (not always, but often) that the weight saving is negligible?
Also, and this is purely a personal thing…but they look gopping, no?
SamFull MemberThere are a lot less design restrictions if you don’t have to account for multiple chainrings, a front derailleur and somewhere to mount it.
1xX is a boon to folks who want short stays and fat tyres.
Also very good for designing rear suspension because you don’t have to worry about mounting a front derailleur or the effect of different chainring sizes on bob.
kayak23Full MemberIt is personal. I think single front rings look way better than multiple, and so does a nicely designed chainguide.
It’s not just about weight either, simplicity is a big factor, less bar clutter too with only one shifter. This is especially true with a dropper post as I can put my reverb button where the front mech shifter used to be under the bar.
A 1x will generally tend to be quieter too. Enjoy the silence..
Someone will be along in a minute to tell you it’s only a fashion thing.. 🙄
scaledFree MemberSo much easier to maintain cadence when you’re just shifting up and down a cassette rather than that horrible jump when you shift down the front ring.
chiefgrooveguruFull Memberby adding something like a 42t rear spocket, a massive cage rear mech, and the requirement for a chain guide
You don’t have to add a huge rear sprocket. You only need a medium cage mech with one of those big sprockets. With a normal cassette you can run a neat little short cage mech. More often than not you don’t need to run a chain guide if you have a narrow-wide ring and a clutch mech.
It’s simpler, lighter and more intuitive to use. Plus you get fitter because you can’t pedal uphill so slowly!
BigDummyFree MemberAlmost all of the frame damage I’ve ever sustained and most of the chain breakages have been due to shifting at the front. If I can get a usable range of gears without a front mech, that’s pretty compelling.
I now use my dropper-post at least as frequently as I ever used my front shifter, so making space for that control is a real advantage too.
Ground clearance is a real thing.
Also, the riding I actually do has long since not really needed the very tall gears. I’m not absolutely sure whether I can do without the very low ones permanently yet.
RorschachFree MemberI’m crap at setting up front mechs.Come to think of it I’m not great at the rear ones neiver.
I’ll stick to single speeds.cookeaaFull MemberFunctionally there is no Advantage at all…
They were invented purely so a different halfwit (unable to use any of the internet’s various search tools) could post pretty much the same question on this forum every week, and get the same answers as the previous Morons….
That makes you this weeks winner OP!
binnersFull MemberGenuine question here: where do you lot who run single rings tend to ride? What are the gradients like?
I reckon it’d be a non-starter for me. I live on a 25% gradient, and I reckon I’d be as likely to make it up there on a 1×10 as I would on a single-speed (which I sold 1 ride after I moved here). There is basically nowhere remotely flat where I live
So… do you regularly ride up stuff like that? And if so, have you got thighs like Chris Hoy?
robinlaidlawFree MemberI saved 1.2 lbs by going from a 2x set-up with a chain device to a 1x with a clutch mech, narrow wide ring and a wee top guide. It runs quieter, smoother and although I initially looked for the lower gears sometimes, I was never actually forced to walk instead of riding, so I clearly didn’t need them. I’d not go back.
stcolinFree MemberI’m about to install my 1×10 setup in the next few days. My reasons for changing are pretty simple. I rarely use the granny ring. I will be able to position my Reverb lever, I’ll save a bit of weight (not bothered), a lot quieter than my current 2×9 with roller tensioner, and the chicks love it*
*unconfirmed
fin25Free MemberLong cage mechs are not necessary to successfully go 1×10, a zee rear mech will work with a 40t sprocket, probably pushing it for 42t, though I am happy to be proven wrong.
robinlaidlawFree MemberFor what it’s worth, I didn’t ever have functionality or reliability problems with front mechs but the bike runs more smoothly without it.
Pretty steep in places around Aberdeen. My lowest gear now is equivalent to just a touch higher than the granny ring and second from largest sprocket, and I was running a 22t granny and an 11-36 cassette. You can cope with that without too much trouble. I’m running 11-42 and a 32t front now and it covers what I need no problem.
chiefgrooveguruFull MemberSo… do you regularly ride up stuff like that? And if so, have you got thighs like Chris Hoy?
Yes to the steepness but it doesn’t go on for that long around here because the hills aren’t as high. No to Hoy-size legs but yes to bigger legs than many MTBers of similar height/weight.
razorrazooFull MemberI can see where Binners is coming from here. I ride a single ring set up (11-36T) as I get the benefits already mentioned (weight loss, simplicity, silence, under bar dropper). I don’t regularly ride long/steep ups or terrain where I would spin out regularly so 2x or 3x is overkill. If I lived elsewhere I may have a different outlook (or probably just add a 40/42 upper sprocket).
D0NKFull Memberbinners a 32×11-42 setup only loses you 1 or 2 granny gears, it’d be reet. Recently put a 1×10 on my CX bike and really like it, seriously considering switching to 32×11-36 when my current (brand new) 9spd drivechain wears, for local riding (will be keeping a granny ring on my lakes bike).
tonFull Memberplain old sales guff.
I am just speccing a new build, trying to find some good quality cheap 9 spd stuff is getting a bit easier…….long live 1 x10 and 1 x11… 8)
robinlaidlawFree Memberbinners a 32×11-42 setup only loses you 1 or 2 granny gears,
In rough terms I reckoned that I lost about 1-1/2 gears at each end, going to a 30t ring would make it one at the low end and two at the high end. I certainly don’t miss the high gears and even as someone who only gets out once a week I can easily manage without the low gears. For me, the big sprocket adapter is definitely necessary, some of my much fitter mates can manage 32 front with 11-36 rear, but round here, I would struggle a bit.
amediasFree Memberto answer OP, lighter, simpler, no big ratio jumps, what’s not to like?
Medium cage mech works just fine, and I only really start to miss anything lower after 6hrs+ when I’m knackered.
Dartmoor, and other local stuff, occasional trips to Wales or elsehwere…
20%+ and rocky/slippy/pebbly etc.
Yes,no not really
34t front ring, 11-34 10speed cassette on HT, 11-36 on FS
36t front ring, 11-34 9speed cassette on XC race bike which to be fair is often ridden on slightly flatter courses, or when it is that steep it’s not for long as the races are only ~1hr so MTFU for racing required.
*all 26ers
ndthorntonFree Member1×10 – nope
1×11 with a 30T ring – yes I think this would be better – but not enough to upgrade until my current drive train packs in.One of my friends just bought a XL carbon 29er with 1×11 and a 28T chainring. The wopping frame and wheels with the minute chainring does look a bit odd.
dannyhFree MemberAdvantages (IMO, obviously):
Less to go wrong
Single ring set up looks better
Can ‘hide’ a right hand reverb adjuster under the bar on left hand side
Shorter cage rear mech possible (less chance of going into spokes and ballsing up the mech hanger – the true reason I went to 1×10 if I’m honest)
Quieter if run with a clutch mech
Makes your legs stronger
Moderate, but still worthwhile weight savingDisadvantages:
You need stronger legs (see above)
Chainring wear accelerated
Might need to add a top guide (very small weight penalty)Truth be told I went for 1×10 because I badly mangled my integral mech hanger by putting a long cage rear mech into the spokes under load. I figured that anything that could use a short cage mech would minimise any leverage of chain flap on the hanger, but more importantly the smaller the mech, the less chance of twotting it on something!
Most of my local riding is rolling hills with a few steep, but short bits. It hasn’t hampered me on away days too much, though – you just need to adopt a ‘shut up, legs’ attitude.
officialtobFree MemberI understand why people may want to go to 1 x 9/10/11… however what I really don’t understand is why people would want to go from 3 x 9/10/11 to 2 x 9/10/11.
What is the reason for that? (slight hijack I know..)
ahwilesFree Memberi’m a luddite, in all the worst senses of the word.
i’ve learned to love the new 10spd shimano stuff simply because of the increased cable-pull; it’s a much more reliable system.
while i’m still convinced that i don’t need 10 gears (5 would be plenty) the new 10spd stuff is very reliable. and if the large + light cassettes grant one all the gear-range one desires, why not ditch the front mech?
…I really don’t understand is why people would want to go from 3 x 9/10/11 to 2 x 9/10/11.
the 40+ tooth chainring is more or less pointless*; removing it allows you to shorten the chain, making it lighter and less flappy. And you can use a short or medium cage rear mech as you don’t have to take up so much slack.
(*it only adds a couple of extra gears, and they’re gears that you only need if you want to pedal to over 30mph – most people never do this. If you DO, then great, crack on, etc.)
D0NKFull Memberwhat I really don’t understand is why people would want to go from 3 x 9/10/11 to 2 x 9/10/11.
old fashined 2×9 was just to get rid of the big ring which hooked up on steps and rocks and stuff, loss of top end speed was not really a worry. Newer 26/40 doubles with a wider cassettes are, I assume, just to reduce front end shifts.
nemesisFree Membersurely by adding something like a 42t rear spocket
They’re pretty cut out so they don’t add a lot of weight and if you use one of adapters from Hope and the like then they’re aluminium rather than steel anyway.
a 1×10 with 11-36 uses a short cage mech so shorter than a triple mech.
for those worried about weight, a NW chainring removes the need
How? Most people don’t even notice. If anything they’re that much neater since there’s no front mech.
Or to put it another way, why don’t you ride with a quadruple front chainset? Answer is obviously because there’s no need and it would have downsides. That’s the same answer for many people as to why they use a 1x
ndthorntonFree Memberhowever what I really don’t understand is why people would want to go from 3 x 9/10/11 to 2 x 9/10/11
that is a far far simpler question
When do you use the big ring off road?
Replace the middle with a 34T and fit a Medium cage rear mech
Job donetorsoinalakeFree MemberI am debating changing my girlfriends bike to 1×10. She doesn’t really get on with the concept of gears and will get off and walk despite having gears left anyway, so it will simplify the issue.
However, the last time I changed something involving the gears on her bike, it went down like a Camelbak full of cold sick. Apparently removing the gear indicators (to get the brake levers inboard for one-finger braking) renders a bike unridable. So I am undecided.
binnersFull Memberbinners a 32×11-42 setup only loses you 1 or 2 granny gears, it’d be reet.
Have you ever been out riding with me? 🙂
I’m quite surprised you only lose that, actually. I’d assumed it’d be more. I still think I’d struggle. As I know every ride from home starts on a 25% gradient, and when I’ve done however many miles I do, finishes on one too. Heres the profile of my road…
How does that look on a 1×10? Its a bloody nightmare with a granny ring!!
DaffyFull MemberCheers everyone (apart from Cookeaa – you Sir, can go and swivel!)
samjgeorge86Free Member1×10 because I can’t be bothered setting up a front mech, and I’ve found I can ride everything my friends do on 2×10 whilst I’m on a 36t chainring. I am from Kendal so ride the Lake District and Scotland, some times Yorkshire. Done 35 mile rides across fells no problem, and never struggle on shorter ones really.
There is less to go wrong, they look better, and they force me to exert myself more, which I like. Yes I could get a 2×10 and sit and spin on the climbs, but I like to make my self feel sick…
11-36 cassette, and all is good.
Everyone is different though, people I ride with won’t go 1×10, and I’d never go 2/3×10. Horses for courses and all that..ndthorntonFree MemberHow does that look on a 1×10? Its a bloody nightmare with a granny ring!!
A 30T ring with 1×11 probably gives you the same gears as with a granny. 28T is probably even more (and too much)
suburbanreubenFree MemberEveryone is getting all huffy and defensive about their low ratios but is the high ratio enough? Do you not spin out going downhill?
Why not MTFU and go SS?freeagentFree Memberhowever what I really don’t understand is why people would want to go from 3 x 9/10/11 to 2 x 9/10/11.
The reason I did this was because the only action my big ring ever saw was taking chunks out of the back of my calf.
I swapped my triple for a 2×9 (22/36) SLX chain set, complete with bash guard, and am now much happier.
I’d be interested in 1×9/10/11 however i’m not fit enough to do away with the granny ring yet.Do you not spin out going downhill?
No, as far as I remember, dropping the 44T, and going up to a 36T on the middle only looses you 2 or 3 gears…
chipFree MemberThe reason I went 2x was I kept bending teeth on the 42 so went bash/36/24 with 11-34 cassette.
Now running bash/36 with 11-40.The way I look at it is the only reason behind the large ring and granny existing was because they could not generate a full usable range of gears with only a single ring and cassette.
Now they can, thus rendering the front mech obsolete .
As soon as you can buy a 10-42 11 speed cassette for £50 I think front mechs will be a thing of the past for many people on here.richardthirdFull MemberBinners’ graph looks more like 10% not 25%. Plenty of hills in-between these gradients on SDW here with 30T 11-36 on 26″
robinlaidlawFree MemberDo you not spin out going downhill?
No, it’s almost always possible to avoid descending anything open enough to need gears that high around here. The good stuff, there’s no way you are pedalling. In some places I can see an issue though, but you aren’t losing all that much really.
Because there’s a very big difference between the 20″ ish lowest gear on a 1×10 with a 42t sprocket and the 50″ ish single gear on a SS and there’s no way I could push one single gear everywhere.
The topic ‘Genuine Question – What's the point of 1*10 or 1*11 setups?’ is closed to new replies.
