Viewing 5 posts - 1 through 5 (of 5 total)
  • Genesis Fortitude owners…
  • brumsgrove
    Would a 44t chainring fit & clear the chainstays?? Or should I re-phrase: Given that the bikes come with a 32T as standard – Is there sufficient room to replace the 32T ring with something nearer 40t-44t?
    steve_b77
    Wouldn’t say so as it’s on the middle tabs of a single ring chain set
    brumsgrove
    I was thinking of running a Surly fixed (135mm disc ) hub, which is apparently designed to run with a 50mm chainline ie. chainring in the outer position.
    Rik
    A 40t should fit, I’ve got a 38t with plenty of room.
    brumsgrove
    Rik – Member
    Thanks Rik…Which fortitude do you have?
The topic ‘Genesis Fortitude owners…’ is closed to new replies.
