Your typical 11-34 9spd cassette has cogs thus sized…
11-13-15-17-20-23-26-30-34
The closest to a 22 granny as you can see is the 23T sprocket, 4th down. So to answer your original question Trout, running a 36T ring with an 11-36 cassette, your lowest gear is about equal to running with your granny ring in the 4th gear down on the back currently.
From what I read about the Design of the Mega, it is optimised for use with a 36T front ring, so might not be wise to run a smaller middle ring, though possibly still wise to keep a granny ring for climbing? That said, I’m now running an 11-36 10spd setup with just a 32T ring on my hardtail, with a bit of a grimace managed a big climb I’d never cleared without bailing out on the granny ring before the other day.
