I asked what vehicle as i thought you where going to use it between a concentric slave & a gearbox casing inside the bellhousing . It would not be suitable for that application .
I’m guesing people have used it on land rover slaves to prevent corrosion between the two surfaces ? I can think of no other reason , if this is the case , a thin layer of grease would be ample i’d have thought .
Personally i like to let a gasket do it’s job without any clag on it . If you do need to give a gasket some assistance then a good quality rtv sealer is what you want . rtv is what you ned for metal/meatal sealing . Avoid using rtv’s on oil feed pipes to turbo’s etc as it can easily block oil ways and galleries .
