I think the water supply is good (cant test until I’m home next month). mid 90s house with plastic pipe coming in and the utility room tap next to where it comes in fires out cold water very aggressively!
Upstairs (3rd floor) the cold water tap is fast too but the hot struggles.
The pipes are plastic but I’ll need to measure them I do think they were on the thinner side than what they should have been (according to the neighbour).
Currently it is a combi. I’ve googled what an unvented system is.. is that likely more powerful than just directly from the combi then? I’ve got no tanks anywhere at present.
The unvented system is simply cold water fed to a tank that is then heated? So I don’t need a new boiler per say?
It would mean losing space in the garage though which isn’t ideal but not impossible…
If the mains supply is good should I just go for a big combi like totalshell suggests?
