Viewing 10 posts - 1 through 10 (of 10 total)
  • Garmin – Loss Prevention Advice
  • curiousyellow
    As someone who crashes a bit I am paranoid that I’ll lose my Garmin in a crash. It’s happened once where I’ve gone over the bars and finished a race sans Garmin. Luckily, someone picked it up and handed it in.
    With my camera, the first thing I do is take a picture of my contact details so if it ever gets lost people know how to give it back. Can someone suggest a similar thing to do with my Garmin please? I have already labelled it, but I don’t trust the labelling to maintain the text in the wet.
    Thanks.
    CraigW
    What model Garmin? On a lot of them, you can customise the startup screen. So I have mine set to display my phone number and email address when its switched on.
    You could also mark a waypoint for “Home”, with your address/phone number.
    Or stick a label inside the battery compartment.
    Also, if you can attach a lanyard, do that, then loop it around the bars.
    nockmeister
    If its an Edge800 then you can display a message on the start screen..
    antares
    Can you, how?
    scotroutes
    There’s a startup.txt file you can edit
    br
    My garmin had the ability to edit the start-up title, so I input my name and phone number.
    MulletusMaximus
    I have a stem mounted 705 and as a little bit of extra security I zip tie around the stem and head unit to stop it detaching if I crash. You can usually position it to lie between the data fields.
    aP
    In 6 years of using stem mounted Garmins I have never had the slightest issue with one coming off. This includes road, cx (inc 3 Peaks), and mtb.
    UrbanHiker
    Lanyard looped round the frame?
    curiousyellow
    Awesome. Thanks people.
The topic ‘Garmin – Loss Prevention Advice’ is closed to new replies.
