Ringo, if you want it primarily for navigation then I believe that there's a lot of better options out there for you. I had the 205, which I think is about the same, for a year and for a navigational aid it's limited. Here's the limitations I found:
1. You can't load maps onto it. That means you can follow the "line" of a previously loaded route but that's all.
2. You can't follow the "line" and record at the same time. This is a problem if you're searching new trails and want to record your deviations from the line you're following.
3. You can't have several "lines" on the screen at once. That means you can't see where you are in relation to other trails until you get home.
(There are other limitations but these are the one's I found most annoying!)
I now have a etrex which is a far superior kit for all the above reasons and more. It's a bit more weighty but not so you'd notice.
Hope that helps. Commiserations on being the worst Beatle 😉
