Just bought a GArmin 800 with the OS 50,00 map pack. Trying to get to grips with the basics and have a couple of qeustions:
1. Is Basecamp the best software for managing the GArmin on my Laptop.
2. In the devices list there appears two drives , one seems to be the Garmin itself and the other I think is the SD card which the OS Map comes on. How do I check the available space on each – can you store tarcks and routes on either – will they both be displayed as courses on the Garmin
3. Is it best to create routes in the library and then export them to the Garmin drive – or is it better to create them on the Garmin HD directly
4. How do you delete routes off the Garmin drive – if I create a route in the library it seems to be easy – but can’t delete them from the Garmin drive – obviously doing something wrong.
Thanks
