Yesterday my Garmin 800 stopped showing its OS 1:50k explorer maps.
They are legit offical maps loaded onto the mini SD card.
In the choose map screen the OS maps have disappeared as an option, but when you plug the garmin into the computer they are on the card. I played around for a bit and for 20 mins got the sd card to read, but on the choose map screen it said OS maps enabled then ‘none’ and did not show in the mapping screen. Now the OS map option has disappeared again.
Tried a different SD card in and the Opensource maps on that one works fine.
Any ideas – I presumd the SD card is fine as the computer can see it when the garmin unit is plugged in.
