Viewing 7 posts - 1 through 7 (of 7 total)
  • Garmin 520 and old style cadence sensor
  • Ed2001
    Will an old style Garmin cadence sensor work with the new Garmin edge 520.Currently using old edge 300 and looking to upgrade.
    Thanks for the help Ed
    simondbarnes
    Should do
    jam-bo
    As long as it’s ANT+
    beej
    You might need to set the sensor type to “ANT+ Spd/Cad” on the Garmin settings. I had problems with my 800 not picking up the new style sensor after having been used with an old style previously. I had to change the sensor type to get it to work.
    STATO
    The 520 menu has option to pair with combined or separate sensors. I use it with both.
    onehundredthidiot
    Should do but I couldn’t get mine to.
The topic ‘Garmin 520 and old style cadence sensor’ is closed to new replies.
