there’s a road uphill from us, but the road drainage works well, so surface runoff isn’t an issue, just groundwater from surrounding higher ground. There’s a stream at the bottom to drain into, so that bit’s easy.
We’re getting in quite a few tonnes of topsoil – hopefully easy draining, rather than heavy/clay! – so that’ll raise the level at the lowest points and allow the rain to get to the drains.
Main concerns are
– coil rather than smooth PVC (he says doesn’t matter – textile will block slit from getting to the pipe)
– fine particles blocking textile, making the whole drain useless
And I’d be interested to know how steep the gradient is of the water table in the soil – say it’s 40cms below the surface in the drain itself, bit higher in the soil next to the drain, how far away will it be pretty much unaffected by the drain?
